Re: Buying a Mercury 6hp -2 stroke or 4
I recently sold a 2003 6hp 4-stroke. I was using it on a 15' modified V Polarkraft. It was light enough to move around fairly easily and it Literally sipped fuel but it had just slightly more power than the oar. Seriously, on a boat that size even a slight head wind could cause some problems. If fuel supply isn't an issue I would recommend the 2 stroke. Good luck.
That could very likely have been caused by the prop. The Merc 4-5-6 HP is the same engine for the most part. The 4 came with an internal fuel tank, and a connection for an external tank. The 5 and 6 only had an enternal tank. The 4 and 5 came equipped with a 7.7 x 7 propeller, but the 6 came with a 7.7 x 8 propeller.
I mentioned earlier, that with my 6 HP, the standard propeller (7.7 x 8) ran great on my 9 ft inflatable dingy. On my 22 ft sailboat, it's another story. That boat wieghs 2600 lbs with no gear or people on it. The 6 HP is adequate at low and midrange RPMs, but will not go to it's full RPM range. I am overpropped in this situation and lugging the motor at full throttle. There are 4 prop choices for the normal high speed props, 7.7" diameter and either 6, 7, 8, or 9 inch pitch. There is a 5th prop which is a 8 3/8" diameter, 6" pitch "elephant ear" high thrust prop available. That is the one I will be getting for my sailboat for the upcoming season.
Like rg2, mine literally sips fuel. Mine came with a 4 gallon Quiksilver tank, which I filled up only once last season, and I still had about 2 gallons left when I hauled the boat out for the season.
The new 6 Hp is also coming out with a few neat features. An internal tank option (like the 4 HP), and a 6 Amp alternator. Both of those can be retrofitted to the older engines. The alternator is another upgrade I will likely get for my engine.
