buy or fix
b9wright
I have an older Nissan 50 (not sure model ns50c) bottom cylinder low on compression. Quoted 1500 for rebuild. Should have rebuilt or try to buy resonably priced used. Any help and suggestions appreciated.<br />Thanks........<br />Bill
TOHATSU GURU
Re: buy or fix
The cost of the repair exceeds the value of this 15 year old engine.
scotty c
Re: buy or fix
i agree, sink that money into a new motor<br />and you will sleep easier at night !
mattsaks
Re: buy or fix
Although... If you rebuild the bottom end you know you can rely on it. The $1500 repair probably doesn't allow for the rest of the engine systems like electrics carbs water pump etc that probably need some attention as well to keep the thing in good condition.<br />It is a bit different where I come from as it is very hard to find a good second hand engine and if you do, you can easily pay $4-5000 for a late 80's early 90's 60-90hp saltwater motor.
