where can i find or buy these bushing<br /><br />they are 1/2 long & 9/16OD 1/2ID they go over the pin then into the hole on the trim & tilt <br />bracket <br /><br />jim<br /><br /> http://www.geocities.com/jimmyp135/
Laker, those look like the bushings we use in reverse gates for riverboat jets here. There are pins coming out from the jet foot that the reverse gate attaches to. I will check on the sizes I have in my tool kit.
Jim, I actually found two kinds. One in plastic and one in Brass. The plastic ones have splits on them to insert them over the shaft and the brass ones are obviously slip in units...The plastic ones are available at my outboard jet dealer and the brass ones are available at a bearing supply store here...Hope this helps. Let me know if you don't have any luck.
