tnanomantube
- Mar 11, 2014
- 2
Hi,
New to this and just became a member, so a big thank you in advance and I'm going to try and do this correctly.
I have a 1993 Four Winns express cruiser with 2 crusader 350's and v-drives. I'm getting no water out of the exhaust and had a very strong burning rubber smell with some white smoke within 3 minute of starting.. replaced the impeller and cleaned the raw water strainers and in the inlet at the bottom of the boat and when I opened the thru hull fitting I could see the water filling the strainer. So started the engine again and initially there was a little water coming out the exhaust but with in less than a minute the water stopped and could smell the burning rubber again but no smoke. Any ideas???????
Also I was told there is a muskrat problem here in the marina with them crawling up into peoples exhaust systems, could this be a possibility?
Thanks,
Tnanomantube
Thanks,
Tnanomantube
