Re: Burned plug on wiring harness, Cause?
1. Answering the question: A burned connector occurs because the connection develops a resistance, usually due to corrosion. Heat is generated by current flowing through a resistance, defined by Ohm's Law: P in watts = current squared x resistance. In the case of your plug, the more heat the more destruction and it is a snow ball effect.
2. A burned open or high resistance coupling shouldn't blow your fuse. Resistance in the circuit means less current, not more. What has to happen to burn the fuse is an outside influence.
The fuse is connected to the engine's low current wiring and contained in that is the wiring from the battery through the start switch to the starter solenoid control wire, which when powered by battery voltage, closes the internal high current switch and applies power to the starter....separate circuit and not fused. Since nothing happens to the fuse until you attempt to start there is something in that circuit that has a lower resistance than required under normal circumstances. So, either you have a wire contacting another along the wiring path I mentioned, or shorted to ground, possibly through the insulation melting, or your starting switch (solenoid) energizing coil is shorted internally.
Disconnect the small power feed wire to the solenoid an, with a new fuse, attempt to start the engine. If the fuse blows you have a wiring short. If not your solenoid is internally shorted. Simple as that.
HTH,
Mark
