foosballpaul
- Jan 19, 2001
- 15
I have a 1980 115 Hp Johnson O/B. One of the pistons is burned and the cylinder sleeve is scored. I was told that the carb for that cylinder was set too rich, causing the cylinder to fire too hot, causing the piston to overheat. Is this a possiblilty? If so, when I repair the power head I will need to readjust the carbs. Any assistance is appreciated.
