novice boater 58
- May 24, 2008
- 3
I just bought a used motor to go on my jon boat. I had a 25 HP and bought a used 40 HP. When I left the landing everything was okay for a few minutes, then the engine cut off. I restarted it several times, but could never get it to run properly, it just limped along. Fortunately I was able to get a tow from someone and got it back to the baot landing. I pulled the cover to see if it might be something loose. I was shocked. My old motor had a pump for the 2 cycle oil with a reservoir. The motor they put on does not so I was running the motor on 100% gasoline for about 5-10 minutes. It will be Tuesday before I can get it to a shop, but am curious what to expect. I'm wondering if I should add the appropriate amount of 2 cycle oil to my tank, mix it up and try it again or take it to the shop. Is this engine completely ruined?
