nagasama75
- Jul 28, 2008
- 5
hello all. i have a 74 135hp silver starflite. finally got it running after some previous problems, ran great for about an hour and i had it @ WOT and it just died. i thought i ran out of gas, so i checked, plenty of gas.
i primed the bulb and it started right up. it would run for a bit, and then die. prime the bulb, it would run for a bit then die you get the idea.
would it be a bulb problem or is my fuel pump not functioning correctly?
wouldn't it indicate the fuel pump as constantly priming the bulb (bypassing the pump?) keeps it running fine?
another thing, the rebuild kit is easy to find (sierra 18-7820 i found the number on another thread here
), and cheap. the entire pump itself is harder to find and not so cheap. my questions are:
which do you guys think the problem is, bulb/line or pump?
and:
if pump, will a rebuild perform adequately? yes i can do it myself i think a monkey probably could, right? looks pretty simple.
thanks in advance and sorry for my poor english
and:
