Josh in Pa
- Apr 29, 2008
- 17
I recently bought my first boat, and shortly afterwards discovered it had a cracked block. I've decided to fix it, and found a block out of a truck of the same year. (1992) The motor in the boat was a 350 magnum. What makes it a magnum? I would like to build my new motor to the same level as the old one. I see engine kits listed on ebay that seem pretty complete. They are for a marine 350. Will these work as long as the year is correct, or does the magnum have special parts? I thought I had read that the 350 magnum had 9.4 to 1 compression ratio, this seems pretty high. Is this standard for the marine 350? I've also found a used set of vortec heads and am considering putting them on the engine. I am aware that I will need new intake. They will also raise my compression, and I am concerned that if stock is 9.4, the vortec heads will raise it too high. Any experience here? Basically, I have experience rebuilding motors, but never a 350 or a marine engine. What is the most economical way to acheive similar or better performance than the 350 magnum that I had? Thanks for any help,
Josh
Josh
