Re: BUDDY BEARING SEEPING
Mine seep all the time...it has nothing to do with any type of failure, in my opinion.  Mostly has to do with the type of grease that's in it...most greases I've found have a tendency to separate a bit and the oil comes out, and I've found that many synthetics are sometimes just as "seepy" as mineral greases.  It's all harmeless unless you let it go too long as it does causes the grease to slightly thicken.  This is one of the biggest reasons Bearing Buddies are NOT a substitue for regular disassembly/inspection/repacking.  The grease does break down over time, even if it manages to stay clean and dry.  So if you're repacking every few years you're in good shape, just ignore the little bit of oil and wipe it up as needed.  Also, if you haven't repacked your bearings yet on your 3 year old trailer that's been dunked 20 times....it's probably time.
