The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
There is a coil for each cylinder most likely one coil has failed very common on older OMC based motors.Pull the flywheel and check the coils<br /> I would replace both and clean and check points condencer and plug wires.Also if you dont know its history change the impeller and be sure the fuel system is clean.
