I asked questions about a DVA . Btheking posted a schematic of a DVA , I have no electronics training , I have carpenter exp mostly and can read a blue print , The guys at the electronics supplier told me wich way the Diode goes , The point is this is not difficult to build . I tested it on the known factor wich is household 120 volt outlet , What I read elsewhere is 120 V will give you 160 to 170 using a DVA with the meter on DC , It did so I tested my motor ,
Someone asked in the thread if it worked , So I built it ,so i thought i would report it does , If any one knows how to post this in the Stator thread will you PM me ?
