Broken Waterpump Housing Suzuik DT90
r2376
Hi,
One of the 4 Bolts that hold on the Water Pump Housing Broke while attempting to loosen. After removing the other 3 and the housing I can see a small dimple that I was hoping try to grip with some vise greps and loosen. I sprayed good with PB Blaster and will try to loosen in about 5 days when I have time. I was wondering if I should try heating up first. I am concerned about warping the alum. or that there may be some plastic there which I can melt.
Any suggesting greatly appreciated.
Thanks
matt2002
Re: Broken Waterpump Housing Suzuik DT90
Try tapping on the bolt head first.It will work the penetrating oil in better.
