Hi all - looking for some insight. While replacing the thermostats on my 2006 BF225, I broke two bolts on one thermostat housing. I know - tough lesson learned. One bolt had some threads showing and was relatively easy to remove. The other is about a half inch down, under the tensioner pulley mounting plate. We've tried a few different methods to get it out, including a screw extractor set, but haven't had success and are worried we're going to start doing more harm than good.
To make things easier, we're probably going to remove the tensioner pulley mounting plate, but to do so we'll have to remove the tensioner pulley and idler pulley. The belt is in good shape, so not looking to replace it, but when we put everything back together is there anything we should be cognizant of in terms of timing? From what I can tell reading-up, as long as we ensure the TDC marks on the crankshaft and camshaft pulleys are all aligned with their marks when we put everything back together, we should be good.
Any advice is appreciated. My father-in-law, who is helping me, was a diesel mechanic for 20+ years, so he's mechanically inclined, but just want to make sure we're aware of any pitfalls specific to a Honda engine.
The bolt I broke is in the hole with the red X in the attached picture.
