Hi everyone, I'm new here and hope that I'm in the right place for technical questions. I as of this year own a 1995 Rinker 180 Which is powered by an I/O Mercruiser 3.0L 4 cyl.
I was boating about a week ago and stopped to let my son get on the tube and so I turned my engine off. I tried to start it but it just made a grinding noise and until yesterday I couldn't figure out why it wouldn't turn over. It appears that one of the starter bolts broke off and fell out and was sitting under the engine. This obviously allowed the starter to rotate away from the flywheel and thus wouldn't allow it to turn over. My dilemma is how to get out the broken bolt piece that is in the block. My plan was to use an EZ out or bolt extractor but I never got that far. I tried to drill it out using a left hand bit but the bit wasn't hard enough to drill the hardened bolt so that plan failed. I then decided to use a carbide bit but this apparently push the broken bolt piece father into the block. The bolt that broke is the longer of the two and its about 4 inches long.
I have two questions:
1. Can I access the other side of the broken bolt if I remove the oil pan to remove it with pliers or something?
2. If I keep drilling and it falls out the other side will it do mechanical damage or will it just fall in the pan and sit there?
Thanks for any information, I appreciate it
