geekomatic
- Feb 12, 2005
- 136
1979 Johnson Seahorse 2HP. I bought a carb rebuild kit plus a new low speed needle valve,which was really worn out when I bought it.I put it back in to avoid losing it.<br />Upon removing the valve, the actual "needle" part has separated (broken off) from the valve and is resting in the hole.How do I remove this tiny piece of brass in order to replace the entire needle valve?<br />Just above the valve orifice, there appears to be what looks like a "freeze plug" that would give me access to this area in order to push the broken piece out.Am I going in the right direction.How do I remove this plug?I just happen to have a replacement if I can get the old one removed.
