Broken gas tank?
duckcrazed
I have a Tempo Ultra PBW (on deck) 13 gallon gas tank. While cleaning it out (water issues), the fuel pickup line inside came off. Is there any to reconnect it? Can the fuel fitting be pulled off the tank reconnected and put back on the tank without ruining it? Figured I'd ask before I ruined the tank, thanks for any input.
Solittle
Re: Broken gas tank?
I don't knoe the Ultra but you should be able to unscrew the fitting then get the fuel pick-up out through the tank cap.
