Re: Broken Bolts update
If the tap is not too far in and if you can get at it is try to take a small punch and a hammer, tap lightly on the flutes of the tap in the direction of removal. This sometimes works but if not there is a neat little device called a "tap extractor". It has splines that fit down the flutes of the tap and fits into your tap handle. You should be able to pick one up at your automotive parts supplier (NAPA) or a machine tool suppier.<br />If you can't find a tap extractor readily, try this old trick : Slide two drill bits down along the shaft of the broken tap, between the flutes, on opposite sides of the broken tap. The drill bit(ordinary 'drills') should slide through; you're not trying to drill out anything, just any two drill bits which will fit between the tap center shaft and the ID of the tapped hole. Using a screwdriver or other suitable pry-tool, try to back the broken tap out by 'twisting' the two drill bits as if they were a pin wrench. You can also resort to drilling two pieces of flat stock to act as 'handles' for the two inserted twist drills, one above and one below the broken tap.<br />Good luck<br />Just my $0.02 worth
