Broke Brass tell tale 2005 F150 TLR
txbandit44
So broke the brass fitting that comes off the top of the exhaust cover and feeds the fuel cooler and then the tell tale on the bottom of the cowl. It not listed as a part number so I assume its pressed into the cover. Anyone know if you can replace these or do you you have to replace the cover? I was also thinking i could drill and tap for a npt fitting but wanted to ask. Cover isbrass.PNG $300
