Navy Jr.
- Sep 14, 2007
- 738
A while back I authored a post regarding heat that I could feel on the outside of the trailer wheels. At first I thought it might be the bearings, but then after towing a few more times I determined it must be the brakes. Sometimes the wheels were warm or even hot, sometimes they're weren't. If it were bad bearings, they would be hot all of the time.
So this morning I broke out the owners manual for the hydraulic brake actuator on our Shorelandr' trailer. The actuator itself is model A-75 made by UFP. I recall reading the manual when we got the boat last year, but now that I've got 40 trips under my belt it makes a lot more sense.
I wonder if the problem has to do with the breakaway cable, the cable that is used as a last line of defense after the coupler falls off the ball and the safety chains fail. The cable would then be pulled and the trailer brakes would be applied gradually to bring the loose trailer to a stop.
When everything is running normal the breakaway cable should never come into play unless, however, it is installed wrong. The manual says, "Inadvertent setting of the brakes by pulling the breakaway cable is the single most common mistake users make. To prevent light pulls from accidentally setting trailer brakes, a small metal clip has been installed on breakaway cable in front of the indicator bead. The clip will not inhibit the action of the breakaway mechanism during actual breakaway condition. However, if breakaway should occur the clip will be destroyed and should be replaced. Spare clips are attached to the cover of this manual."
There's also a pushrod on the bottom of the actuator that is used to release the trailer brakes after they have been activated by the breakaway cable.
Interesting stuff.
When we bought our rig the salesman showed me to attach the breakaway cable to the forward side of the left ring on the hitch that one of the safety chains hooks on to. I'm thinking it should probably be fastened to the rear most part of the hitch so it would have more slack when making tight turns.
Have any of you had problems with your breakaway cable inadvertently setting your brakes ever so slightly?
Interesting stuff.
