Break in suggestions?
rodknee1231
1973 evinrude 135 I only replaced one piston the rest have good compression all above 120 service manual suggests 50:1but that's a 40 year old book so what's recommended now a days. I'm about to start it on muffs today or tomorrow
jimmbo
The 24:1 mix was to be used for the first 10 hours
Since a piston was replaced, and the remaining pistons hopefully re ringed, it needs to be treated like a new motor. Soooo...
During the first Hour - For the first 5 - 10 minutes, operate at a fast idle. For the remainder of the first hour, do not operate over 3500rpm, If your boat planes easily, it would be ok to bring the boat using full throttle then immediately reduce the power to 3500 rpm. Be sure boat maintains planning at this setting. vary the speed a bit every 10 - 15 minutes
During Second Hour - Bring boat onto plane, reduce power to about 4500, at intervals apply full throttle for periods of one to two minutes, then return to around 4500
For the next 8 hrs, avoid continuous full throttle for extended periods
