Rob Fisher
- Feb 11, 2002
- 6
Just picked up my new Stratos yesterday and had a question for the experts in regards to the proper way to break in the motor. It is a 2003 200hp. Evinrude with Ficht Ram Injection. The dealer told me that to break it in it should take 5 hrs. They told me for the first hour I should run it no higher than 1500rpm and no longer than 5 minutes at a time. The second hour no more than 2500rpm w/ 5 min. rule and so on until I hit 5 hrs at 5500rpms. Now my problem is that the service manual says its for 10 hrs and in an almost oppisite way with running the motor at a high idle in gear for the first 10 min. than going up to 3500rpms for 50 min. no longer than 15 min. at a time . (confused yet? I am)The second hour I should take it up to full throttle to plane the boat and than come back down to 3/4 full throttle and at intervals apply full throttle 1-2 minutes and return back to 3/4. <br />For the next 8 hrs.I should avoid continuous full throttle for extended periods. I know I should probably just go by what the manual says bur the mechanic at the dealer insisted I do it the other way because he said its the best way to break in the Evinrude. So you can see my dilema. Any experts out there that can help me on this? Sorry so long. Thanks
