I have a 1994 25' Searay Express witha 5.7L Mercruiser with Bravo II drive. Everything worked fine until this weekend when I took it out drove about 10 miles shut the engine off. When I tried to start it, it would crank about 1/4 turn or less and jam up with a loud clang. It's not a weak battery or cable problem. I also noticed I couldn't get it into forward gear easily. I worked the shift back and forth, and then I was able to get it into drive, but then it wouldn't go into reverse. Note all this shifting is while engine is off as the drive(or something else) is locking up the engine. With the engine off, I was able to verify that the prop turned both ways in nuetral, one way in forward and opposite in reverse as it should.
The drive has about 600 hrs on it and I'm assuming it's shot, but can someone tell me what it is that most likely failed? The clutch assembly? I havn't taken the boat out of the water yet, to see if there's water in the oil. A few other questions- How many hours is a typical Bravo II drive expected to last? Also, If I replace it, do I need to buy a Brovo II?
Thanks,
Jerry
Thanks,
Jerry
