Hi All, I have a bravo 3 that failed a pressure test and it was leaking from the inner prop shaft seal (the seal between the big and small shaft). A huge thanks to Alldodge for his write up especially the hose clamp trick it works perfectly. Boat is in salt water and it kicked my butt getting the bearing carrier off. I broke 4 1/2 inch breaker bars, after more heat and pb blaster i finally got it off. Got everything back together, pressure tested it to 10 pounds and it held it over night. Pulled vac to 5 pounds and it drops pretty quickly.
I know merc says you dont vac test the drives but i see that others do and they hold vac. So is there another hidden issue and is it just maybe one of the seals isnt holding vac but pressure and it doesn't matter.
Drive was disconnected for test. Thanks again.
