Re: bravo 2 water pump
Impeller and wear plates should be enough. And you know you can turn the wear plate over once right? So you might just need an impeller!
If your housing looks like this, you might consider changing it.
But please note, this pump was working fine when it was taken apart, no overheating at all. Just maintenance. Bravo pumps can last a long time if you boat in clean fresh water.
