Bravo 2 in salt brAckish
04martinaj
Moving to south Carolina, and really want to take my boat with me... im running a 5.7 mercruiser with a Bravo 2 in a 94 wellcraft... plan on dry rack storing. I also plan on changing my anodes to zinc , and installing a flush system. Can I expect motor and outdrive to hold up ok?
Lou C
Yes just keep up with maintenance such as pulling the drive at the end of each season to check the driveshaft bellows for water and grease the gimble bearing and u joints if they are grease-able. Keep in mind in salt water exhaust systems do not last as long as they do in fresh, we usually check and replace them at 5-7 season intervals.
If you are rack storing you should not have problems.
