lknlover
- May 15, 2009
- 18
I just had my Bravo 1 outdrive rebuilt due to a faulty yokeseal and since re-installed it has drained an entire oil reserve reservoir. Since out first trip out where 1/2 inch or more disappeared - refilled- then overnight lost 1/8" in about 24 hours and another 1/8" after a good ride - WOT 75mph. The drive is connected to a 500HP -
How much oil should have been consumed once the drive has been ridden?
Will it stop after a couple of times out or is something else wrong?
I will check the levels again in the morning. The mechanic wants to pull it again but if he does I won't see it for quite awhile as he is covered up with business.
Help me decide! Did you all follow this? I hope so.
