How do I remove my MerCruiser bravo one prop
Ayuh,.... Welcome Aboard,.... If there's a tab washer, pry the lock tabs up outa the slots in the castle washer,....
With a 1, 1/16" wrench on the nut, 'n a piece of wood 'tween the prop, 'n cav-plate, turn the nut lefty loosy,....
When the nut comes off, pull the prop off,....
If the prop don't pull off, wack it with the piece of wood, 'n
Pray the last guy greased the propshaft before he put the prop on,...
