Bravo 1 leak
mpdcam
I recently removed my Bravo 1 outdrive to store it for the winter. When I seperated the unit from the boat, I noticed milky white oil leaking from the outdrive where the shift cable connects. The o-ring around the shift cable connection was new this year. Any ideas what the problem is? Thanks
TilliamWe
Banned
Re: Bravo 1 leak
Right above that is where the fitting for the reservoir bottle sticks out. You sure it's not leaking from there?
Regardless, milky white oil leaking is a bad thing.
