Bras keep popping off
Chris611
This post won't be as exciting as the subject line may indicate :D . Anyhow, one of the 4 bras for my bearing buddies keeps popping off about 5 minutes after I park the trailer. What is causing this? Do the bras wear out or is there some sort of heat build up? any help would be appreciated.<br /><br />Thanks<br />Chris
JB
Re: Bras keep popping off
Trailer topic.
Silvertip
When you install the bras use one finger or thumb right in the middle to push them on. The center of the bra will be concave due to a slight vacuum. If you just slide them on they trap air and as a result, there is a positive pressure inside so they pop off.
crazy charlie
I push in the center as well to make a vacuum and I also put a strip of duct tape collaring the edge to make the cap tighter.
John McFarlane
Secure each bra with a radiator hose clamp. Then you don't have to worry about any negative or positive air pressure in the hub from cooling/heating. And it needs positive pressure to maintain its effect.
