Hi, I have a 1982 Yamaha 55hp EL outboard (labelled Mariner but essentially the Jap Yamaha version). The starter motor packed in so I bought a brand new one, wired it up and fitted it last week. I tested the engine on the drive way and all was great, starting like a dream. I got it on the water today and started initially and we cruised for a while. After stopping for some lunch I went to start it again and nothing, not a thing!!!
On getting it back home I have established the following:-
There is power getting to the solenoid and the solenoid is working (you can hear it click when the start button is pressed.
The battery is pumping out just under 13v at the engine block. The earth to the starter is good as is the positive.
If I bypass the solenoid the starter does nothing at all.
I can spin the bendix and its not jammed at all.
What else can I try. Could the starter motor be broken even after a week?
Should I just torch the whole boat and engine?
