I just bought a brand new 2010 9.8. It will start up and idle fine, however if I rev it up ( either in natural or in gear ) then bring it back down to idle it will sometime stall out. But then if I pull it it will start up again and idle just fine. I don?t understand what the problem is, like I said it only does it sometime, and sometime it seems just fine. Doesn?t seem to matter if its warmed up or not, I can take if for a half hour ride and it might stall out when idling back to the dock. The only time it shows any problem is when I throttle back to idle, anything above idle speed and it runs like a Swiss watch. Its not a huge issues because its still under warranty, but it is something easy like a carb adjustment I would just assume take care of it myself. And before anyone asks, Yes, I put the correct amount of the correct oil in it. The gas line is connected correctly, and the vent cap is open.
Thanks for the help
Thanks for the help
