brake fluid leak
bijou22
one of the pipes on my ez loader trailer is leaking brake fluid. will it still be ok to tow my boat on the weekend and get it repaired at a later date?
Dunaruna
Re: brake fluid leak
No. <br /><br />No fluid = no brakes. No brakes = decreased stopping ability, especially in an emergency.
rwidman
Is it a slow leak and you can top off the master cylinder every few weeks to maintain braking or does it spray out when you apply the brakes? If it's just a slow leak and the brakes still work, you will probbably be OK. If it's visably leaking (dripping or spraying), don't tow it anywhere but to a repair shop and do this very carefully, realizing that there are no trailer brakes.<br /><br />If it's leaking at a fitting you may be able to tighten the fitting with a wrench and fix it yourself.
jeff_nicholas
What size boat? What size tow vehicle? How far do you want to tow it? How fast will you go? What kind of traffic?
You're Kidding,..... Right,..??...<br /><br />'Cause,.. If it's Leaking Fluid Out,.....<br />It's Also Leaking Air,+ Water IN.........<br /><br />That trailer Already Doesn't have Brakes on atleast 1 Wheel Now..............<br /><br />Get It Fixed...........
bijou22
thanks for all the advice. I did tow the boat and it was fine. The brake pipe had completely snapped and there was no fluid in the system. Now its time to get it fixed.
SwampNut
It's a done deal now, but for others thinking this is a reasonable thing to do... It worked out because you had no emergencies. If you had to slam on the brakes, the full force of the trailer would have made an emergency stop much more dangerous, and greatly increases stopping distance or worse.<br /><br />I had the line explode on my trailer once (faulty installation by the manufacturer). There was a huge difference in stopping ability.
MRS
Friend of mine had and old willeys jeepster re did it nice to original including drum brakes. Had a 21ft. center console surge brake leaked he said no big deal it wasnt till loaded boat at end of day left marina it is down hill to hwy. with a stop sign. Go to stop at stop brakes wet he was wet and C***88 pants did not stop but made to hwy. luck nobody else was crossing. Next day got disk brakes put on front end took trailer in and had surge brake fixed checks brake system constanly now. :eek:
SwampNut
Did he have to get his seat re-upholstered to cover the hole? (From his sphincter bunching it all up?)
rwidman
You're Kidding,..... Right,..??...<br /><br />'Cause,.. If it's Leaking Fluid Out,.....<br />It's Also Leaking Air,+ Water IN.........<br /><br />...........
Not kidding. <br /><br />It depends on where the leak is. I had a very slow leak because of a (very slightly) loose connection at the "T" just behind the master cylinder where the system splits to go to each side of the trailer (not all trailers are set up this way). The brakes still worked fine, just a few drops of fluid leaked out each trip. Once I discovered where the leak was, I corrected it, bled the brakes, and everyting was fine. Not much chance of water or air getting into the system in this case.
MRS
Swampnut Pucker Power was why off the scale that happened years ago but I think he is still picking material out of his teeth. :D :D
woosterken
:eek: Ithink this should be moved to STUPID human tricks.<br />KEN
