Re: Brake drum removal with buddy bearing?
tommays, I didn't remove the buddy bearing cause I wasn't able to get the cotter key out. The housing that surrounds the hub was about 1.5" deep and I couldn't get in there to pull the cotter key out, otherwise I would have removed the nut on the spindle and pulled it off.<br /><br />Is it possible that this housing pulls off first and then I can access the cotter key?<br /><br />I've done brakes on many cars and trucks and the only difference here is that the chrome housing is over the cotter key and nut so I can't get to them. The housing I'm referring to is what holds the cap that has the grease fitting on it and it's got a spring behind it. There is a snap ring on top keeping it installed and then a snap under the spring which I thought would allow the drum assmebly to pull off of the spindle when it was removed. <br /><br />I don't think the brakes are holding the drum cause it spins with no drag, in fact they are probably way out of adjustment.<br /><br />Like I said, if it's the nut and cotter key I can't get that cotter key out without removing the chrome sleeve first.<br /><br />Thanks for the help. If you have any other ideas I would like to hear them. Unfortunately I don't have immediate access to the trailer, it's a few hours from where I am right now so I have to take notes and try and get it apart when I can get back up there.
