brain teaser
crab bait
ATTENION:: puzzel has been solved.. if you want to try an solve it yourself,, don't read past this/my post... for the answer is below..<br /><br />1-o<br />2-o<br />3-o<br />4-o o o last 2 are 5 & 6<br /><br />here's a brain teaser.. wish i could show you's in person but the price of gas limits that so here's the best i can do.. <br /><br />here are 6 coins layed out on a bar top all conjoined / touching together .. 4 down,, an 2 across.. as in a L shape.. the 'o' are the coins.. the numbers,, i gave as to give them an abortrary lable/name.. ( easier to show an explain )<br /><br />i suggest you's do the same.. lay out coins.. <br /><br />to reiterate.. 6 coins total,, 4 down 2 across,,all touching ,,in an L shape..<br />it's that simple ..that easy...no trick here..<br /><br />now move any coin to make TWO rows of FOUR coins...an mulitple moves are accepted but not required.. <br /><br />ONE RULE... CAN NOT ADD ANY MORE/EXTRA COINS...only the 6 coins,, are the only coins allowed..no more coins to be used...<br /><br />in closin'.. there is NO trick ,i promise.. SCOUTS HONOR.. there is not verbal trick,, i.e. have to listen to every word for a slip up.. it's not about that,,at all ... an totally do-able.. i promise,, no trick ,,here at all...<br /><br />1-o<br />2-o<br />3-o<br />4-ooo <br />love to keep the answers secreat for alittle while so all can try... but o'well
LadyFish
Re: brain teaser
I'm workin on it Crabby.
JB
Re: brain teaser
My brain hurts. :(
SCO
Re: brain teaser
you put the top coin of the L on top of the joining coin at the bottom of the L. was easy after concluding that you have to go 3 diminsional!
JB
Re: brain teaser
Good show, SCO!! :D
tylerin
Re: brain teaser
20<br />30<br />4000<br />-156<br />Coin 1 is on top of 4
one more cast
Re: brain teaser
here's one for the kids. place a coin on the table,cover it with a coffee mug so you can't see the coin, now say "I'll bet you I can get the coin out from under the mug without touching the mug, SHAZAM the coin is gone" when they pick up the mug to look, grab the coin...you did it,you picked up the coin without touching the mug. :D
crab bait
Re: brain teaser
YOUR . R I G H T. ,,SCO...!!!<br /><br />i was showed this the other day by a 6 year old kid... i really really tried ,,almost to brain hemorage... to no avail.. <br /><br />when the kid finally showed me,,, boy ,, was he in trouble..!! i chased that lil'crapper thru every room in house... ;) ... <br /><br />i so enjoyed this puzzel ,to where i'll never forget it,, that i really wanted to share it with yous.. but was contenplating it.. not knowin' i could explain it rite... <br /><br />i'm glad i did, tho...for only to hear J B say " my head hurts " ... boy, does that make my day... thats somethin' you don't hear everday..!! i finally stumped 'DA MAN'..!! ;) ....
SCO
Re: brain teaser
Thanks. Usually I don't get them, but this time it clicked.
