Bracket for fenders??
kozman01
On one side of my old trailer, the two thick metal brackets have broken off. Does anyone know where I can get brackets that can be bent to shape it to the old ones? The metal doesn't have to be thick enought to support weight, I can get into the boat ont he other side using the good fender, I just need to have the fender supported. Thanks for any help!
Bob_VT
Re: Bracket for fenders??
I used heavy 8" L brackets from a hardware store. They came galvanized and are pretty heavy duty. They mounted on the frame and supported the fender.
kozman01
Were you able to bend them or are they a straight, rigid "L" bracket?
They'll All Bend,.........<br /><br />If you have a Big Enough Hammer..........
BigPoppaG
Originally posted by Bondo:<br /> They'll All Bend,.........<br /><br />If you have a Big Enough Hammer..........
Another fine suggestion from our resident experts.LOL :D ;) <br />That is how I do it. <br />If it won't fit..............make it fit. :D
Bob_VT
Yes when I had to bend them slightly I fastened on end to the trailer and used a pipe over then end to band them a bit.
