I am sure this topic has been discussed on here before, but I am new to this forum so I am going to bring it up again and maybe somebody can give me some insite.<br /><br />After a closer inspection, I believe I have finally found the cause of my idle problem. It turns out the reeds were not sealing. One of the reed blocks was even rusted and pitted. Somebody suggested replacing the reeds with Boyesen reeds. Do these really make a difference in performance? I know my factory reeds are bad and I will need to change them, but I am wondering if they will be worth the money? I have read that it will change the performance of the motor, but I would like to have the opinion of somebody who has actually made the switch. What exactly do they come with? I will need the block for sure and of course enough reeds to change the both sides. I should be able to obtain the reed block from a friend of mine, but I was wandering do they come with the new reeds?<br />By the way, the light trick worked. I used a flashlight in the dark and was surprised how much light you could see around the edges.
