boy did i mess up
airraider
Just bought a 84 mod v side console with an 84 mercury 50 on it . Got it home and went to show my brother how the engine purr like a kitten , hooked the water muffs up turn the water on ( or so I thought ) and proceeded to turn the motor over . Turned it over , and it ran for about 3 secs , turned it over again and the same thing happened ... I continue to try and turn it over for about 15 sec and it wouldn't fire . Walked back to the motor and no water is goin to the muffs. I had hooked up the muffs to the wrong hose and didn't even check to make sure water was flowing . So I'm assuming I probably burned the impeller up , what do u guys think? I'm goin to check it when I get off work today , but my question is what else do I need to check?
Taylorsville
Re: boy did i mess up
With it being only running for 3 sec i doubt you did anything to it. But no matter what you should always check the impeller on a used motor. It is good to know everything is good before you take it on the lake.
Chris1956
Yes, the impeller was not affected by so short a run. You will want to replace it after you get the beast running. I would recommend you take a compression test, check for spark on all cylinders and reprot back. If the ign and compression are good, you could have a bad enrichener or idle circuit in the carbs.
Hubboat
Could be a lot worse, it's good practice to replace the impeller anyway, who knows when the previous owner did so.
Moody Blue
There you go, not as bad as you thought. That doesn't happen to often :D
