I Have A Yamaha 175 TLN V6 3K4295 I went to change the oil for fuel mixture because I has been setting for over a year without being run so I Grained both tanks the one in the boat and the one on the Motor and I pulled out the sensor device of of motor tank to fill it back up. But when turn the key back on the three lights RED yellow and Green it went to Yellow in stead of Green so now when the key is turned on the oil blows out of the top of the cap. WHAT a miss. Iwould not be missing with this but .i took it to a wrench last year after it started missing real bad i was told it needed a carb job itit ran fine the next trip. I was told to put an aditive in it i ask if i needed to to run all the gas out he said no so i took it out and it last weekend and it idle ok but it bog down when it went to to low range but i pushed throw that and i ran good in meed range.but in top end it it would bog down again i would have to back pedal it untill i could get agood speed out of it. my typing is not the best. so i apoligize . so if any one could help me. i would gratefull .thank you and HAVE A NICE DAY
