I have a 19ft Wellcraft bowrider....this Spring I want to mount a hand controlled bow mount trolling motor. My questions are........
Can I get away with a 12 volt system for lake use or do I have to go with a 24 volt system with more lbs of thrust?
What legnth shaft on the trolling motor will I need?...my boat is a pretty standard 19ft bowrider...
If I got a wild hair.....could I use a freshwater trolling motor in salt water and just rinse very well when I pull it out of the water?
Is mounting an on board charger the way to go?
Thanks
Thanks
