Re: Bow stop question.
Thank you guys!
I've already learned the problem of not using two straps up front. On the way home from the lake, after we swapped trailers, I had the front strap come off when I hit a bump.
Due to having to much rear weight on the boat, improperly adjusted trailer, the boat "stood up" a little bit. I about died of a heart attack as did my friend behind me.
I'm still working on getting the boat on the right spot on the trailer and should hopefully have that done tomorrow.
I had moved the whinch stand forward, but not far enough apparently.
