Bought first boat... Engine questions???
Joecool
Hello all. I just bought a 1986 wellcraft elan. It has a 185 hp mercruiser engine. The original owner bought it, took it out about 5 times(says he)and its been sitting in storage ever since. I put new rims and tires on it to bring it home and just ripped out all the corroded seats. The rest of it looks great. The motor is an inboard motor and when I lifted the seats and saw it I was amazed that it looked brand new. I want to make sure I do everything correctly as to not screw up the engine. I've drained the gas out of the tank (about 20g). What all should I do before trying to turn it over? Where could I get a manual for maintenance? And how do I know exactly what kind of engine model it is? Also where is the best place to get seats? Just the local boat dealer? Or is there a good place online to purchase? Thanks in advance for any help?
dhammann
Re: Bought first boat... Engine questions???
Congratulations on your find!! Boating can be a fun and inexpesive pastime with a little elbow grease and the desire to research for knowledge, it sounds like your on your way. First drain all fluids, engine, outdrive, trim hydraulics then replace with new ( Walmart is best buy) use a #30 straight weight high detergent oil, Walmart brand is excellent change gas and oil filters. Be sure to use gear oil in lower unit that is certified for that purpose. The gas in the carbureator has probably turned to varnish and clogged the idle passages, the fresh gas may clean it out....if not you need to diassemble it and clean. Check the 3 rubber bellows behind the bellhousing and check for dry rot or cracks, if it was stored with the out drive in the extreme up position this is very likely. If the bellows look good spray with a silicon spray (armoral or equivlant)<br />Grease all zerk fitting on bellhousing and also trailer hubs. Get a new marine battery, you don't need anything pricy($40-$50) Before you turn over your engine spray some silicon spray into the water intake screen on the lower unit the install flush earmuffs and turn on garden hose about halfway. It will take some time cranking the engine before the gas will fill the carb. Do not crank engine more than 15 seconds at time, and wait several minutes to allow starter to cool. You could speed this up by spraying starter fluid in carb. but make sure you have a fire extingusher handy. When motor starts check to make sure water is coming out exhaust ports on bellhousing...if not shut down and check pumps. Let engine idle and listen for noise while turning steering wheel left and right, any grumbling soung indicates U-joints or gimble bearing. Check out Overtons on line, they have everthing you need for cosmetic restoration and also repair manuals. When you take it out on the water for the first time do it with someone who can help you with a tow in case you need until you blow all the cobwebs out. Good luck!!!
Joecool
Thanks big dee. I will print this out and get started! Any other advice is greatly appreciated also.
cclemon
Mr. Cool<br /><br />Congradulations and welcome to boating. My advise is not for getting started this year, but for getting started next year. "Winterization". If you live in a part of the country that gets below freezing in the winter, you will want to make certain you follow the manufactures instructions for winterization. Some motors will freeze and bust just like car blocks. Remember Mr. Cool when it gets cool, keep cool, winterize. Lots of Luck, have fun.
