Bought a replacement Merc 3.0 Engine - wrong flywheel/coupler
islandboy47
My Mercruiser 3.0 motor bit the dust so I bought a rebuilt one from a mechanic online. The motor is all well and good, but when looking into putting into the boat we realized the "new" motor came with a different sized flywheel and doesn't fit the coupler I currently have. After doing some Googling now I realize there were two different versions of this motor where they changed the flywheel size and coupler set up. Now I'm totally confused about what to do - I know I have to use a different starter than what I currently have (the reman engine has the straight bolts for the starter, not staggered) but I have no clue how to address the issue regarding attaching the flywheel/motor to the outdrive. Obviously I wish I had done more research and known about this compatibility issue beforehand, but here I am. Has anyone here successfully remedied a situation like this?
kenny nunez
If the bolt circle on the replacement engine is larger than the previous engine then you will need the following from Sierra Marine. 877 663 8396
18-72510 stud kit
18-2171 Coupler.
Double check with them but this should get you back in the water.
Yep ya bought a older 3.0
Hey @Bondo could use your advise
Ayuh,...... Welcome Aboard islandboy,...... Sierra sells an adapter type crankshaft mounted coupler, with the right bolt pattern for that motor,.....
I don't have a part number, but it should be an easy search,......
With only the straight pattern starter, ya gotta use the small flywheel,....
edit: thank you kenny,..... that one,.....
islandboy47
Thank you guys! After posting this I found that coupler online and thought maybe that's what I need. I never would have known to get the stud kit.
