Is is possible to put the wrong manifold on a mercruiser? I took my boat to the shop and had a 2005 Rebuilt engine installed to replace the old 89 that finally bit the dust. I think they used all of my parts on this engine including the exaust manifold. The head has 6 bolts but the manifold only has 5.
It worked for about 10 hours before an exhaust leak in the bottom center occurred. There is NO hole in the old manifold gasket and i put a new one on it and it still leaked in the exact same spot. I did that TWICE before trying to use exhaust gasket sealer around both sides and letting it sit for 24 hours before i started it. Only let it idle and still leaking out of the bottom in the center below bolt 4 from the left side.
I sanded both surfaces and they seem smooth, I put a flat level on it and it appears flat...
I guess I just need to pony up the money for a new manifold? Because the engine is running great.. sat for 2 months started up on first key turn.. i let it idle for a little while.
