Re: Bought 230 Scorpion now have questions
I agree with most of what oops says but I would not sand dry. Wet sand paper tells me better what it is doing by how it feels. Your boat doesn't have clear coat. The gel coat on a boat is way thicker than car paint so you should be able to get back to shiny without fear of sand through.
I did this myself last spring, got compliments all summer cause my 23 year old hull looks shiny new.
How much fuel is in there. Sniff it. If it smells like gas just run it out. If it smells like varnish get it out so you don't run it into the filter, pump & carb. An ounce of prevention is worth a pound of cure every time.
Your boat probably has a spin-on fuel water separator filter. Buy 2. Change 1 right away and the other after you have run the tank a bit. If you are curious you can dump the contents in a clear jar each time to see what the separator caught, I would recommend doing that. Don't reuse the filters.
Have fun, those Scorpions have a good ride, I bet you'll have a great time.
