I bought a 15hp Honda kicker today and I have some questions.
First off, it's my first Honda, or even 4 stroke for that matter. The data plate is missing, so I can't get a model number. I believe it to be a 1990's BF15. Shaft length is measured at 23", which is a shame because I need a 20". Is a "Long" shaft 20"s on an old honda, and I might have an extra long? It has a 10x6.5 four blade prop, is that a high thrust prop for this motor? I got it cheap and it has a brand new carb, manifold piece from carb to block, plugs, oil, impeller, and maybe something else I'm forgetting. Throttle linkage is a little wonky, I think I might need a new rod from carb to tiller crank assembly, the one I have isn't threaded on the end and it appears that's what I need.
And here are my real dumb Honda newbie questions:
Does it have a Honda specific fuel connector, or is it OMC like it looks? I didn't want to force my OMC hose onto it.
Can you put controls on these? It didn't look very obvious.
Feels like about 100lbs, is that the same as the 9.9?
Is the one I have basically the same as the grey square cowl motors?
Unfortunately I'll likely have to sell or trade it off for a 20" shaft 4 stroke, but I'd like to know what to tell people I have.
Thanks
Thanks
