rookieboater
- May 25, 2004
- 16
I want to have my ff powered from the hot side and auxillary side of the ignition switch. I tried to wire my ff onto the auxillary side of the ignition switch (refer to July 03, 2004 post) so I can use it with the motor running (boat running) and with the key switched onto auxillary (boat not running just sitting). My ignition switch has only 4 terminals on the back and only one (I used an amp meter) is hot with the switch on auxillary (radio is also hooked to this terminal and works with switch on aux). When I connect to it, I have power to the ff (when switch is switched to aux.) but the hot side of the switch (the one the ff is hooked to with the switch turned on) also is getting power from the aux. connector. Hope I haven't confused everyone. My question is this, how do I connect to both sides of the switch without energizing the other connector? How can I separate the two sides of the switch and have power to my ff, the stereo runs off both. Again, thanks for your wisdom and help......rookieboater
