bottom paint
fluke you
I need to have the bottom painted is it something I can do myself? The boat is 24 center console on a trailer
R Socey
Re: bottom paint
Sure you can - what kind of shape is it in?
Fireman431
Re: bottom paint
Why are you painting it if it was kept on a trailer? Was it painted previously?
Are you looking at an anti-fouling paint or something to make it look new again, such as awl grip?
fluke you
Re: bottom paint
yes it was painted before and it is coming off in places from the powerwashing.
R Socey
Re: bottom paint
http://www.yachtpaint.com/LiteratureCentre/bare-fiberglass-bottom-paint-guide-usa-eng.pdfhttp://www.yachtpaint.com/usa/diy/default.aspx
You should be able to get the info you need from this link.
I have a 25' on a trailer too. I don't want to tell you the way
I'm going to do mine because I'll scare you off - I want to
encourage you. Remember you can spend a lot of time, and
money on a paint job, or not so much. I would recommend
Interlux VC performance epoxi as it is hard paint for a trailered boat. Make sure you familiarize yourself with saftey precautions.
Boat paint can kill you - never sand without total protection.
Never use products with isocyanates without a fresh air in-duction resperator system. A good prep job, and good products
makes the finish. Go for it - you'll be proud of yourself, and take
more pride in your boat, and probable get a better result. Don't
hesitate to ask for more advise. Good luck
Fireman431
Re: bottom paint
Awl grip is boat paint that is used for restoring the appearance of a boat when the gel coat is no longer able to hold a shine. Look at the pic of my boat in my avatar. It is painted with awl grip.
Re: bottom paint
i was wondering the same thing my boat is trailerd but i am planing on putting bottom paint on it. i am planing on beaching it and leaving it in the water for a week a time some times. i was wondering would the truck bed liner stuff work on the bottom? also whats a good cheap paint that you can use on the bottom?
Fireman431
Re: bottom paint
Truck bed liner paint is too rough. Just get the bottom paint thats designed for it. Trinidad is about $100.00 a gallon.
R Socey
Re: bottom paint
VC performance epoxi is designed for trailered boats at $200.00
per 2, gal kit. You don't need an ablative paint if you only keep
your boat in the water for a week at a time. Nothing marine is
cheap. The reason your paint job is failing is probably because
whoever did it before didn't want to spend the necessary time,
money, or effort.
fluke you
Re: bottom paint
I actually keep it stored at a launch and go , I only have it in the water when I'm on it then pull it out and leave it trailered. It's my first boat so I am learning as I go. Thanks for all the help everyone.
spikeitaudi
Re: bottom paint
If you don't actually leave the boat in the water why bottom paint it? If you are doing it to restore the looks that makes sense. But if you are putting Antifowl on that isn't nessicary.
dingbat
Re: bottom paint
My last two boats had bottom paint on them when I bought them. I removed the bottom paint but the surface had been etched and needed a lot of work to get it back looking good. Decided just to put a hard anti-foul back on it and forget it. I used Fiberglass Bottomkote? NT for this application.
You can use NT it to paint over just about any paint and there is no special prep required. At the time it was something like $80 a gallon and I got 3-4 years out of an application. If the paint showed signs of staining, I just rubbed the paint down with a wet sponge and it looked like new again.
Re: bottom paint
Why bother doing anything? It's not hurting anything the way it is so just leave it. Once it's in the water, the fishys are the only ones looking at it.
