bottom leg
guru
On my 1980 9.9 chrysler on the bottom leg there are to plugs one says oil and the other says vent. what is the vent plug for do i remove this when adding gear oil.<br /><br />thank you
ob
Re: bottom leg
DLM,Yes.Remove both plugs and add gear oil from the bottom until it weeps out of the top vent hole.install the top vent plug first as to minimize oil loss from bottom hole and then reinstall bottom plug.This fill method insures a sure fill without any air pockets forming.
