bore
Eshaw150
what is the std bore on a 1990 v6 johnson 2 stroke motor
im think im going to half to do a rebuild
and im going to get the block machined
Faztbullet
Re: bore
If it is a crossflow 3.500 (175 crossflow came as a 3.625)
the 60 degree is 3.600 and the looper is 3.685. Yours is a crossflow.:D
Eshaw150
Re: bore
the motor just had the third cyclinder rebuilt bet to comp is as follows stating from the left side looking at the back
1-85
2-83
3-74
4-90
5-90
6-91
Faztbullet
Re: bore
Looking at rear of engine cylinders are labeled as so:
2 1
4 3
6 5
Which cylinder was rebuilt and why??
Eshaw150
Re: bore
6 has ben rebuilt and only now has 74 psi it was rebuilt due to bad rings and a blown head gasket when i bought it i new about it he told me it had been extermly over heated the walls were scored meidum to badly
u couldnt even tell it had rings they were flush with the piston
i spent over 300 for one cyclinder
and now i found a whole rebuilt kit for 700
it like it starbving for gas could the fuel water seperator be the cause of it
and today i put a new set of ngks in it stsrted a lot eiser though
Eshaw150
Re: bore
it was honed it looked pretty good but i dont know to much
im honestly think about getting a used 4 stroke or a new etec
